Flurette Farm
Model 315.
If you have the bale knives set parallel and need to adjust the gap between the knives how can you tell which way you should turn the cam or if it has taken all the slack up?
If you have moved the knives a close together as possible and the gap appears to be right can you turn the cam either way before tightening the locking nut and achieve the same result?
The manual really doesn't say.
