First time poster, be gentle!
My 48 Ford Tractor 8n. Side mounted distributor was swapped to EI several years ago. After some tinkering and sitting around for almost 4 years, I got it up and running. It ran great for a couple of hours then started spitting and stuttering and shut down. After working thru some troubleshooting I replaced the EI and it started up, running like a little sewing machine.
Now that it idles like a kitten, it won't accelerate. The linkage is doing its thing and opening the throttle and whatever that sping loaded thing does next to what looks like a fuel pump appears to moving when the accelerator is moved. There is no change to the RPMs. If I cycle it down it chokes out the engine, when I return the throttle to the mid spot it starts up and idles. When I go full throttle the rpms don't change from idle speed.
At your mercy for suggestions at this point. I feel it's still an ignition issue but after replacing everything top side I'm out of ideas. Plugs wires cap rotor.
