Hello all, as per the title, my tractor has ceased to charge my battery.
My tractor is an '52 8N sidemount dist. ser. 8N513747. 6v, pos ground.
My dad went through this tractor probably about 25 years ago. It has been pretty flawless until now.
I have found a test online for the generator that consists of grounding the field and putting the neg side of the battery to the armature. this test does make the genny spin. so far so good i suspect? i also believe that it is a 2 brush vs. a 3
i looked at the VR (i think? is it located behind the dash on the right side under the oil pressure guage behind the oil bath filter??) if this is correct, this VR does not look like the ones that i see in numerous pics. My VR has 2 terminals on top and 1 on the side closest to the steering column vs. all 3 terminals on the top.
As of now, i keep the battery on low charge for a day so i can mow the grass or a while. it hasn't quit on me yet but don't want to get stuck in the field either.
what other tests can i perform to narrow down where the issue is? as always, i bow to the folks who have forgotten more than i will ever learn.
thanks for any tips
thanks for any tips
