Olliejunkie
My 3010 has sat a few months and now won't start. The tank only had a few inches in it and may have lost its prime. My book says to bleed filters then crack lines. I'm getting no fuel to the lines at the pump. Is there a bleeder on the pump? Thank you in advance.
There is no bleed screw on the injector pump. But you can open the timing window on the injector pump, two screws, to see if there is fuel running out. If the pump was full of fuel, then try to start tractor with window open? Does it start and run? If does run, the governor retaining ring has fallen apart. Pieces have plugged the return fuel line. Need to rebuild the injector pump. Contact Diesel Tech. He can help you.
Thank you. I couldn't remember exactly how to check that. Seems strange that it ran good when I parked it but definitely could be the problem.
UPDATE: I pulled the the rectangular cover off. I have lots of fuel there. I cracked a injection line on the pump and still no fuel. Don't know if I need to crank it longer or if something is stuck. It was running a few months ago when I parked it although it was pretty low on fuel.
He said there was only a few inches in the tank though and on a 3010 it would be below the pump.
It may have been to low. I added 5 gallons and there's was very little air in the filter. I think delivery valve or shut off is stuck. Probably is time to have it rebuilt though.
