No oil pressure.
ruschman
Is there a sequence of things I should look for. There are no visible leaks when running or after being parked. Oil spurts out of block at gauge fitting. New.tube and gauge. Gauge responds to air pressure.
Any help or ideas would be appreciated. Over my head when inside the engine.
First, what tractor do you have and how long have you had it?
Second, is this a new problem or how long has this been going on?
Third, my TO-20 has plenty of oil pressure cold and warm.
The tractor is a work in progress. It's a ferguson to30, and I just put a new gauge on. Didn't have one before. The ret of the answers I don't have.
What is the range of the gauge on its face. A 0 - 80 psi gauge may not give a reading on some of these old tractors. You likely should only need 0 - 30 psi gauge.
A gauge tells you there is oil under pressure getting to the gauge. You could remove the rocker cover and see if oil is getting to the valve train.
Jim, that is what I needed to hear. Thank you. Can I assume up there will be a flow of oil rather than a spurt hitting the ceiling. I guess I shouldn't n e too picky.
My TO20 with 10w30 T5S Shell oil runs 30 lbs of pressure on a hot day brush hogging . Coolant temperature was 190 degrees. Oil pressure drops very little at idle. Pull your rocker arm cover and see if you are getting oil to the top.
If it runs long enough you should have a flow. It might spurt as air is pushed out on start-up.
Two things to try first , don't trust the gauge , try another and compare if you can .
I only work on and own UK TEA and TED 2Os . On these there is an oil pressure relief built into the oil filter housing . Sometimes all that's necessary is to screw the adjuster down a few turns . Otherwise the spring or ball bearing that controls flow may need looking at .
Thank you Charles.
Anyone know if this is true on TO30s? I've heard of there being some adjustment, but thought it was inside the engine.
Photo of my oil pressure gauge this morning after one hour running slasher. Low idle and high idle. This is OK pressure for Continental. Standard Motors TEA Fergies ,would have higher oil pressure I think.
