No power steering
RPNB
Wondering if someone can help me out. I have a late eighties model 562 Belarus that I broke the steering shaft on. I had repaired and after putting it on I now have no power steering. I got water in the system that I have flushed out five times I have bled the lines for air several times.There seems to be plenty of fluid coming from the pump but the cylinder doesnt seem to do anything.Everything worked fine before the shaft was broken.Any ideas?
(quoted from post at 23:31:55 11/13/20) leaking banjo fitting? Happened on my Zetor.
Thanks for the response,but could you tell me what exactly is a banjo fitting.The only leak I can can at the moment is a slight one from the back of the cylinder and its very small.Thank you kindly.
What type steering is this?
Does it have a standard steering gear with an external assist cylinder attached to the linkage?
Is it a self contained power steering unit with an internal assist cylinder?
Or is it a Orbitrol system?
Hello RP welcome to YT! I am attaching a link to show you an example of a banjo fitting. The bolt is hollow and
cross drilled to allow fluid flow. The part with the hole looks sort of like a banjo thus the name. I am just
guessing that 2x4 meant that the intake side of his hydraulic pump had a banjo type fitting and was leaking air
so it could not draw fluid up to it to prime, purely my speculation. Another poster ask the question if your
system is ..self contained.. which means does it have a pump on the engine that only supplies fluid for the
power steering. By searching for a replacement PS pump for your tractor that appears to be the case. Can you
describe what you are referring to as ..broke the steering shaft..? Is this shaft one that slides in and out of the
cylinder? If so that is generally referred to as a ..ram.. I assume you removed a part of the system to replace it,
have you tried loosening the fittings that you disconnected and the operating the unit to bleed trapped air out?
That would be my first recommendation. If that doesn’t seem to work I would secondly suggest jacking up the
front of the tractor so it can move the steering freely, this is also in an attempt to free trapped air in the system.
As a disclaimer I have only been within 3 ft of an operating Belarus tractor one time and have never worked on
one. Just giving you options from general repair practices.
Banjo bolt example
Thank you for your responses again. I googled banjo fitting so I know what that is now.My system is a hydro static power steering system that has all hard steel lines that I have never taken off only loosen to try to bleed air out.The shaft broke at the spline which actually goes through the radiator and into a collar which is attached to a worm gear which connects to the hydro static pump the shaft does not connect to the cylinder The main pump drives off the motor and powers the hydro static pump which I guess is the power assist.It sends fluid through a valve to the cylinder. I hope thats not to confusing.When the shaft broke it left enough spline to still connect to the collar. I took it to a machine shop where they broke the shaft up closer to the steering wheel and put another sleeve on it and some keys to give me enough length again.To reiterate I had no issues with the power steering before the broken shaft,but none since replacing the shaft.
Sorry, I don’t have any other suggestions other than maybe loosening the lines at the cylinder to see if air is
trapped there. Did you try jacking the front up? So the shaft broke that connects to the steering wheel? Did it
seem to be extremely out of line? I don’t see how a shaft could break on the input side with no more than hand
strength on the wheel turning it.
yes I tried bleeding the cylinders with no luck. I have not tried jacking it up, I will try that next.Thank you.As for how or why it broke is a bit of a mystery.I am using it to get firewood and while backing up in low range with wheels turned slightly my front left tire started jumping and snap went the shaft. I was on solid ground not stuck or anything.One theory is the differential is tied into steering hydraulic unit and maybe it malfunction somehow and activated,but there is no reason for that to happen.
(quoted from post at 22:43:19 11/13/20) Wondering if someone can help me out. I have a late eighties model 562 Belarus that I broke the steering shaft on. I had repaired and after putting it on I now have no power steering. I got water in the system that I have flushed out five times I have bled the lines for air several times.There seems to be plenty of fluid coming from the pump but the cylinder doesnt seem to do anything.Everything worked fine before the shaft was broken.Any ideas?
well I am back up and running again.The issue turned out to be a check valve problem.A friend gave my a manual with a break down of a danfoss pump which showed a check valve which essentially was just like a small ball that got out of place somehow that prevented oil flow to the cylinder.
