no power to points
BOH
I have a buddy that acquired a 2n. He has power to the coil, but nothing to the points. Should the wire running from the coil to the distributor be some sort of a resister wire? It looks like somebody did play with the wiring! Thanks in advance
(quoted from post at 17:08:15 01/18/21) I have a buddy that acquired a 2n. He has power to the coil, but nothing to the points. Should the wire running from the coil to the distributor be some sort of a resister wire? It looks like somebody did play with the wiring! Thanks in advance
ore explanation needed, as there is no "wire running from the coil to the distributor" on a 2N, only the spring like primary contact on bottom of coil and the HV tab on bottom of coil.
Thanks for the reply. Any idea what the trouble could be? I am not familiar with this vintage at all. Thx
for the sake of discussion, the coil and distributor on a 2N are a single unit. as JMOR states, there is no wire running from one to the other.
an 8N has a separate coil and distributor, with a wire connecting them.
it would help to know which we are talking about here. a picture can be worth a thousand words :)
Spring/pigtail may not be making contact with concave screw inside distributor, copper strip may be broken or shorting to metal parts, insulators my be bad (allowing path to ground), etc.
Just have to eliminate one by one. Even the little cotter pin can be installed such as to ground the points spring.
Unless a previous owner or his buddy did a hollow out coil and a round coil add on. Anything is possible. Pictures would help.
To clarify, the 9N, 2N, and early 8N used the front mount distributor --- with the square can 1-Wire coil. You refer to the later 8N with the angle (side) mount distributor.
FORD 8N TRACTOR WIRING AFTER S/N 263843; ANGLE (SIDE MOUNT) DISTRIBUTOR:
Tim Daley(MI)
OK. The proper term for that is a front mount distributor. There should be battery voltage to the top of the coil when the points are open and about half that when the points are closed. Since the title of your original post is "no power to the points" run a jumper wire from the non grounded side of the battery to the top of the coil. If the tractor fires you know the problem lies in the wiring up to the coil. If there is no spark, then the problem lies inside the distributor. To service the points, you remove the distributor (there are two bolts). The points are changed on a bench. Gap is .015. The distributor will only go back on one way because of an offset tang which mates to the camshaft. Note, remove the cap before you remove the distributor and note which way the rotor is pointing.
