TEKelly
I have a White 2-135. When you put it in reverse you can feel the gear but when you let the clutch out there is nothing. Same with the gear straight back from reverse. Any idea?
Have you figured it out yet? Have the cab mounts settled so the linkage is out of adjustment? Try unhooking the linkage and shifting it manually on the side. CAREFULLY start it, let the clutch up and see if it moves that way.
