Hi guys...brush hogging with my 8N and she died in the middle of my pasture. Determined no spark. Cleaned points and she started right up. Went a lap or two more and she died again. Installed NEW points and condenser and she started right up. Went a lap or two and she died again. Installed a new coil. Did NOT start this time and it got dark. Going back out in the pasture today to revisit. If it's not the points and condenser and it's not the coil, what should I check and/or replace next? It's a side mount distributor (thankfully) and it's still 6 volt, so there's no ballast resistor, battery is good. There was 6 volts going in and coming out of the coil and at the points, but it goes away, leaving no spark. Something gets hot? I doubt that because it happens after several laps at the same speed and operating temps, and doesn't restart when it cools off. Anybody got any ideas?
Larry in Ohio
Larry in Ohio
