Charliespride
Hello, trying to get dads ol farmall going. No spark though. Tractor never would show a positive reading on Amp meter but has ol dead battery in it to complete circuit.
Anyways, I put new points, condenser, rotor and cap in it. The distributor shaft bushing/s are fairly worn but I see the flat Bakelite plate that sits under the rotor keep shaft fairly rigid. I do remember Dad had points set pretty wide and after he passed away in 04' I couldn't get it going and once I seen the gap I thought geez pop it's not much wonder she wouldn't start with that much play in shaft and I reset points to some where I think it was .16"-.020". Once I realized how sloppy the shaft was I then realized why he had then set so wide. Haha. That was 10yrs ago and never did get it runningbut now I want to hook her up to the discs to work a small plot of land beside our house.
So yesterday determined as I was I went to driveshed to get her running. But no spark. Hooked the 6volt battery charger up to battery leads and pulled on/off switch and sure enough I have power to points. I thought if I took a small tuning screwdriver and open the points a bit I might see a spark jump but nothin. Hmmm
So here I am looking to the smarter folks out there in hopes they can lead me in right direction to hear her breathe life once again.
Yes I drained fuel tank and cleaned sight glass and put a few gallons of fresh hi test in in and I am indeed getting plugs wet by hand cranking.
Thanks all in advance for any and all help. Ernie
