No Spark on 850 ?
gunny2
Was running and starting great,until i went to start it recently. Its been sitting in my garage for a 2 months and now it cranks ,but no spark at the plugs. I converted to 12 volt,pertronics ,10si 3 wire,Flame thrower coil. Where do i start to trouble shoot ? Thanks for your time. Don
Start with the basics. Power to the coil?
Power past the coil with the "points" open?
Power through the distributor feed through the side?
It kind of depends on how you hooked up your EI, but
the basics are the same. Power applied, ground switched.
This is the time of year that mice look for a warm place to hunker down for the winter. Check for chewed wires or other signs of mousal abuse.
