49 model 8N front mount 4 nipple dizzy, 6 volt pos grd. Tractor has been "farmerized" with the wiring harness, nothing matches color wise. Had old pass thru type amp meter that did not work and no ign switch. PO just shorted the wires together to start it. I replaced that with a push pull switch and all was good. Then I replaced the old amp meter with a new 2 post type, I made a terrible mistake of cutting all the wiring loose from the terminal board with the resister in it without marking where each one was located. I evidently connected a couple of them wrong. Jmor and the F04 got me fixed on that and I put it all back as he and the book described. Now I have NO fire at the plugs, grounded one to a known ground source and NO fire at all. Did all the dizzy checks listed here in other checks and NO help there, still NO fire. Jmor suggested shorting across the resister on the terminal block but I already have the dizzy off for the other checks. My question to anyone than might help......WHAT NOW??? I DON'T WANT TO THROW PARTS ON JUST FOR FUN. It does seem like that IS the last resort but I need help before putting it all back together for nothing. I already have ordered new harness, point , condenser, cap and coil but not a dizzy from this site, should I get a new dizzy from Ford (closest is 40 miles) or the land of almost right (TSC) just to eliminate the possibility of a bad dizzy or condenser?
Thanks all of you that offer help and to Jmor especially for all the time he devoted to trying to help me.
Fred
Fred
