no spark ford naa, 6 volt, positive ground...what would be the procedure to jump the coil...use the positive battery terminal to what side of the coil?...thanks mike
(quoted from post at 10:36:35 09/23/22) no spark ford naa, 6 volt, positive ground...what would be the procedure to jump the coil...use the positive battery terminal to what side of the coil?...thanks mike
o, you would use non-grounded side of battery, but....unless you have verified that points are making & breaking the electrical circuit, you are wasting your time.
I think you look closely at the coil, it should have a + and -.
I think the + side should have a wire going to the points and condenser. Don't jump that wire.
To jump it you should run a wire to the - side of coil to the - of the battery.
To play it safe rig a wire with a 10 amp fuse.
It's better to flow a fuse than fry the points..
(quoted from post at 07:36:35 09/23/22) no spark ford naa, 6 volt, positive ground...what would be the procedure to jump the coil...use the positive battery terminal to what side of the coil?...thanks mike
No.
Best case, you will do nothing at all. Worst case you will create a short circuit.
Verify you have a positive ground system first. The + post on the battery will be connected to the frame of the tractor at the other end of the cable.
Once verified, you run your jumper wire from the - post of the battery to the terminal on the coil that has a wire that goes back toward the ignition switch. This wire will NOT be connected to the distributor, and may simply disappear into a bundle of wires up underneath the hood.
If the tractor is wired properly it will be the - terminal on the coil.
