My 8n will not start checked for fuel its ok so I took a spark plug out put the wire on it turned her over and no spark used a test light on top of the magnito had power took cap off and magnito used test light on both ternimals ont he bottom of the magnito, hope that is spelled right, no power showing. Is there any other way to test this to see if this is the problem? Thank all of you out there for all your help!
Lots and lots of threads about no spark in the archives. We need to know if you have a front or side mount distributor and 6 or 12 volts. The diasnostics and fixes are different.
Michael ,If you have power to the top of the coil,you should also have power to your test light on the bottom spring on the coil.If it doesn't have power at the spring,the coil has a open in the internal wiring and it is bad and needs replaced.
Michal, that is NOT a magneto. That is an ordinary (but strangely-shaped) point/coil/condenser/distributor. Get the FO-4 manual and read about it. Simple...after you read about it. You can do this.
