Wallaby
I have switched my front mount coil over to the round coil. I have 12 volts come out of three coil with the key on. When I turn it over I do not get any spark from the coil write when place next to the block. What am I missing?
Is the distributor side of the coil at a constant 12 volts?
It should not be. It should be 12 volts with the points open
and drop when they are closed.
If that isn't happening check your points and the connections
to them to make sure they are functioning correctly.
put a test lamp inline with the wire fromt he coil to the dizzy.
crank over... lamp should blink.
if it stays on or never comes on, post back.
