nutsoverJD
I have a B that won.t start. It is a styled 50's something serial # past 201000 I opened the case to verify timing marks on both flywheel and gov. Mag seems to trip at LHEO when mark on flywheel is inline with the case mark. I bought it not running but did get it to run before. It ran ok but won't restart. It has spark I cleaned the carb. checked timing and reset mag. I don't have LH impulse mark on the flywheel just LHEO and TDC with degree marking. If I put the TDC marks Inline with the case mark piston is not at TDC. I time it as the manual say feel for compression and stop at marks on flywheel cover. However, my LHEO mark is at the case mark. Should I feel compression when turning to this position? Should the TDC mark be inline with my flywheel cover as the manual says??Others on this page suggested switching the plug wires. I haven't done that yet
