no steering
part number E4NN3503CA $1,224.57 3-7 business days. Except............. 3-7 business days is Fiat dealer code for NLA. So you need to order it from your friendly local salvage yard. Or you can probably get by with some smaller parts. Go to Messick's, they do a big on line business.
Bearings out on steering worm shaft most likely.May have more damage if water has gotten inside. If you do not have experience with repair or rebuild on this or know a tractor mechanic who does then, i would recommend looking for a complete used assembly from a salvage yard.
Is it power or manual steering?
Manual, there is a mechanical failure in the gear box. The complete assembly is available here.
If power, could just be low on fluid, bad cylinder seal, pump, valve. Could be simple or expensive, depending on what's wrong.
Steering Gear
Start taking the steering apart, it's already broken, what do you have to lose??? Who knows, it maybe as simple as a sheared key.
