Norden axle
Goodman
I don't think parts are available for Norden wide front axles. Where can I get replacement felt dust seals? Are the same diameter as another felt seal I could purchase.
I believe Swartz ( not sure of spelling ) purchased Norton. I had a Norton on a 560 IH that needed some repair and found out that anyone who carried Swartz parts could get parts for a Norton.
Most of those aftermarket wide fronts are set up to use the same wheels, hubs, etc that are already on the tractor, so the dust seals you need are most likely an IH part.
Just take an old fuel filter to an oil furnace and open it up to fit and then thin it to suit for thickness. I have used them for several things like that.
I take one of the larger sections and then go to work. It will come off the center screen tube by working it down to the end.
Felt weather-stripping might work if all else fails. Cut to the proper length, formed into a circle, and then glue the ends together.
In case anyone reads this later. Found the bearing seal and the felt seal on eBay cheaper than I could purchase bearing seal only locally. Thanks.
