NOS 650 key switch
Looking for a NOS key switch, 366313R91 is the original number but it subs a couple times, the older number has screws to hold eyelets for connections, the newer ones have male spade connections, just wondering before I cut the harness and change ends, thanks
If you can't find a switch with screw terminals, you can use a couple of adapters like THESE to adapt the new switch to the existing ring terminals.
<img src = "http://media.diversitech.com/web_image/6209.jpg">
A refrigeration parts supply distributor MAY have them.
Or, if an EXACT in appearance replacement is NOT required, there's lots of aftermarket switches out there, the one at the link below, for ONE example.
Screw terminal switch
Been many years since they used the original style switch so I would say very hard to come across a new old style. I have been soldering on the (I think Packard style) for years and slip the insulator on also , like wiring in 66-86 have always used.
