Not sure what to think?
while changing oil on my 960 ford I had to pull the oil pan because the previous owner over tightened the oil plug. While cleaning the oil pan I noticed a woodruff key in the bottom of the pan stuck in the sludge. I have no idea where it came from but it's been there a while. I'm not sure what part of the motor has a woodruff key but I know I'm lucky. I also noticed another odd thing while looking for a home for the key. The camshaft was stamped diesel and its a gas tractor? Since I changed oil I have noticed :
-Smoke out the valve cover breather and oil filler breather that it didn't do before
-No blue smoke out the exhaust
- I have oil pressure
- Runs fine
- Maybe dry sounding lifters (but I maybe my imagination by now)
I'm not sure what is going on with these two items but I am looking for advise if there is actually a problem or not. Thanks for your help Scott
Here is my take, I am others will weigh in. Adjust valve clearance (lash). You can remove the valve cover with the gas tank on. Observe top end oiling with the valve cover off. The only woodruff key I can recall is the camshaft gear on the crank. I imagine the talent before you dropped the key and it was too much trouble to retrieve. The old oil may have been so thick it controlled the blow by, run a compression test. You should have 120, 70 or so the engine will have a hard time starting (ie worn out). If the engine runs fine, doesn't knock, starts ok and the top end (valves) are in adjustment and have oil, run it.
