'Nother Note To Dumb Self
Allan in NE
Never try to haul 13 big round bales on that sled. Makes the tires fall off.
I knew she was kinda heavy on that load. 3 hours and a $260 mistake. :>(
Allan
Just to make you feel better, here is what I did yesterday. I was driving the Bobcat when it just died. spent about an hour checking everything I could including pulling the carb. Wife came by and asked if it had any gas in it. Checked the gauge and it showed 1/2 tank. But I thought OK I"ll poor a 5 gallon can in. Of course a few cranks to fill the carb and it fired right up. Didn"t spend any money but what a waste of time. Then when all was done and I parked it the gauge showed a 1/4 tank. I guess the gauge was stuck. Talk about feeling stupid.
Yep, our same setup(old stackmover) that we used to use CONSTANTLY ate wheelbearings. One set a week on average. Twine would wrap around the axles, take out the seals, and that was that....next step was backtracking along the road to find the missing wheel/tire/hub assembly. Flat tires weren't as common but when they happened it was usually with a load of bales so they didn't get noticed until the rim was toast...
"I", and "me" may beat the tar out of "myself" If he does it again !! (Grin). I hope not because when they work together in harmony they make great music.
Did you guys replace the 80w-90 in the trucks with wheel bearing grease?
Big boys say that makes 'em last a lot longer.
Allan
Well, at least the other tire didn't blow from carrying twice the load. If that would have happened probably would have taken out the rims to. Few years ago I had a full [read, overloaded] load of corn on the C60 grain truck. About 4 miles from the elevator, bang one of the inside rear tires let go. I made it the four miles tho, leaving black tread marks on the pavement from that super loaded tire the whole way. Just never know when a tire will let go.
On ours we welded a piece of steel on either side of the pivot shaft so they cant' oscilate as far, if you have a flat or blow out it won't wipe out the wheel.
We also have been running the 12.5-16 from Firestone in a 14 ply, they don't blow out and will last a long time, but are an sob to put on, and will run about 330 mounted with new tube.
Nope just repacked with nomal grease and sent em on their way..... wasnt gonna be too long before the job needed done again anyhoo....
Cured that problem for now with a new bale mover built by Kramer outta Atkinson NE- has pickup arms on each side like our old stackmover did and LOTS better wheel/hub assemblys!
