Notice a difference? 7.5L15 tractor fronts
rockyridgefarm
A rim got bent up on my 3010, and the tire was going flat over a couple days. I decided to change it. I have a bunch of 5 Inch rims laying around. The old rim was a 6 inch.
Can you tel which one is 5 inch and which one is 6 inch? Does it really matter?
I doubt it matters. I bought a 9n Ford back in 99. The winter of 2019 I decided to replace a rear rim. Found out I had a nine inch and a ten inch rear rim. Owned
it for twenty years and never noticed.
Unless you know somebody with such wide set eyes that they can see both sides at once, I don't know that anybody'll notice. LOL
Doesnt matter. The sidewall will be a fuzz wider(or narrower) on one,the height will be the same, I have the same deal on my 8N. 4 wide rim on one side,5 on the other. Same hight. Only if you know and look
real close can you see a difference.
(quoted from post at 11:10:45 07/07/22) A rim got bent up on my 3010, and the tire was going flat over a couple days. I decided to change it. I have a bunch of 5 Inch rims laying around. The old rim was a 6 inch.
Tube the old one....
Make sure you repack the hubs with good quality relative bearing grease so that both wheels turn together evenly....
Looks like a Roll-O-Matic front end. Both tires will carry the same load regardless of any difference in tires or rims.
