numbers on my ford 2000
hello friends , I found some numbers on my ford 2000 , is these the ones that would tell me about the tractor? CONN 60150
That's the engine block casting code and the last digit is probably a C or G not a 0. Find your starter and look for a flat spot on the transmission case immediately to the rear of the starter. There should be two numbers there, a model number and a serial number. The model number is probably something like 21201. Also look under the hood for a foil sticker with model number, serial number, and other numbers (It may or may not be present and is sometimes illegible).
thank you Andy , I will check it out!!
