O 14 fuel pump
Pump will only pump fuel about 12" high no more.I looked around tring to find an answer.One guru said I may have the check valves backwards. Don't the little discs go down first then the springs and then screw in the covers? Thanks chuck K.
Two issues can reduce fuel pump lift. one is a weak spring pushing on the diaphragm, the other is internal leakage back through the valves, or a hole. Distance pushed on the actuating rod is also important. A worn rod can limit travel to such a short stroke that it pumps little. A worn lobe on the camshaft is also possible in conjunction with the rod issue. Jim
NOT exactly sure how your fuel pump is made, but typically the spring locations vs. the disc valves would be opposite, between the suction and discharge valves, sort of like the newer pump with unitized valves in the photo below.
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/Stuff/valves_zpstbeck8uv.jpg">
Chuck, Sounds like you have an uncaged check valve in your fuel pump, that is the older style. The picture that Bob has posted is the caged check valve, that would be in the later fuel pumps. You need to check all the Jim has listed for things that could be wrong. Push rod needs to be about 7-1/16" long. oldiron29
