Found my drawing of the fuel shutoff stems in my 860. I have 3 valves, the original, one I got from another supplier and the one I got from that supplier to replace the one that leaked after 6 months. When the second replacement valve leaked, I began my investigation. The two new valves I got have different stem designs. The original is like the "older" one shown in the drawing below, bt the nose is rounded, rather than stepped like the older replacement valve stem.
I highly recommend anyone having trouble with a leaky valve to do some research in regard to o'ring materials. This is one of the best sources for information regarding materials.
The O-Ring Store LLC : O-Ring Compound Selections - O-Ring Cord Stock | Buna-N, Viton, EPDM, Silicone OSK™ O-Ring Service Kits OSK™ O-Ring Repair Kits OSK™ Hydraulic Cylinder Seal Kits OSK™ Air Nailer O-Ring Kits OSK™ Sanitary & Brewery Gaskets O-Ring Lubricants | FN Lube & FN Lube Plus Olypsys®...
www.theoringstore.com
There are 3 important factors in selecting o'rings. Chemical resistance, Operating temperature, and abrasion resistance IF the o'ring is in a dynamic (moving) application. In a static application abrasion resistance is not so much a factor..
As mentioned before, I have found HNBR/ HSN to be the best for this application.
Buna-N Nitrile (NBR) will work but they are less resistant to abrasion and the upper temperature range is lower which can be problem give the location of the valve above the engine and in relatively close proximity to the muffler.
Vitron has a higher upper temperature limit 482F, but the lower limit -8F is often reached here in Ohio. It s not as abrasion resistant as the HSN,
Still have not found my stash of extra o'rings, but still looking.
