O/T 1992 Buick
I have a 1992 Buick Lesabre 3.8 that refuses to idle smooth and hesitates upon acceleration. After it began doing this, I have put a new gas tank (needed one anyway) in, sending unit and sock/filter, fuel pump, fuel filter, and plugs and wires. And it still runs the same. It runs great when your driving. Just idles terrible and some times stalls. Any ideas? Thanks. in advance
That just leaves ,Module , coil , valves, egr valve , Vac leak , bad/dirty injector , crank sensor , MAF sensor , TPS , CTS ,OS sensor ,ECM , on and on .. Why not spend few bucks and have it diagnoised ? End up saving yourself $$$$ and headaches
Bryan in Iowa always has good advice.Take it in and have it diagnosed.
One easy thing to try before that is to unplug the mass airflow sensor and see if the problem goes away.May need cleaning or replacing.
Something quick and cheap to look at first.
Fuel delivery is based partly on engine temperature, so make sure your radiator, overflow tank, and especially thermostat housing are full of coolant. Burp the system to get the air out if you add any coolant.
Look for vacuum leaks including the brake booster. If you don't find any good chance the EGR valve is leaking. Seems like there was an updated gasket with a screen in it to prevent bits of carbon from getting stuck in the valve holding it open a little.
