O/T 2000 Impala
Christos
Ok, I have a non-tractor question for you. I"m having issues with my Impala. There is radiator fluid leaking from some type of orifice (I don"t know what it is on top of the fan shroud/radiator right next to the radiator cap. The radiator cap was replaced this summer.
I only use the green antifreeze and the car has 253k miles on it. The car doesn"t overheat at all I just can"t figure out what"s wrong with it. My buddies at work don"t know what its leaking out of. I do have the 3.4 engine in it...is it the head gasket leak?
Christos
This sounded familiar.Here's the service bulletin:
Bulletin No.: 00-06-02-001
File In Section: 06 Engine/Propulsion System
Date: January, 2000
Subject:
Engine Running Hot, Overheating and/or Loss of Coolant (Polish Radiator Filler Neck and Replace Radiator Cap)
Models:
1999-2000 Passenger Cars and Trucks with Composite Radiator End Tank
Condition
Some customers may comment on one or more of the following conditions:
^ Engine running hot
^ Engine overheating, and/or
^ Loss of coolant/low coolant message
Cause
The radiator filler neck may have an imperfection in the sealing surface.
Correction
Important: DO NOT REPLACE THE RADIATOR.
Using a piece of 400 grit wet/dry sandpaper backed with a flat piece of wood, polish the filler neck sealing surface using a circular motion.
Replace the radiator pressure cap with a cap of the same part number as shown in the GM Service Parts Catalog.
