O/T: A question for TOH
Do you hire out your time for machine services? I have a dearborn 14-59 sickle mower that I am working on and the PTO shaft needs some work. I need to turn down a 3" section of the shaft from 1.5" to about 1.31" to fit inside of another piece of shaft. I know the last time I spoke with you that you were really busy, so if you don't have time to mess with it I understand. Thanks Justin.
(quoted from post at 11:18:37 12/10/14) Do you hire out your time for machine services? I have a dearborn 14-59 sickle mower that I am working on and the PTO shaft needs some work. I need to turn down a 3" section of the shaft from 1.5" to about 1.31" to fit inside of another piece of shaft. I know the last time I spoke with you that you were really busy, so if you don't have time to mess with it I understand. Thanks Justin.
That would be a quickie and no problem to do if it is not too long for my lathes. Max length I can fit between centers is about 30". If I can chuck one end and support the outboard end with a steady rest I can go a bit longer. Give me a call.
TOH
301.655.0631
Thanks TOH! The whole shaft is only 9" long, so it should fit no problem. I'll give you a call in the next few days when I get some free time. Thanks again
