O/T All Fuel Flue
WWS
I'm getting ready to install an "All Fuel Flue" in my 1,200 square foot shop, question is should I go with a 6" or 8" flue, should I spend the extra money for stainless steel? I dont ever think I would ever need a big stove since it's well insulated and will have a 100,000 BTU hanging heater in it.
You don't say what you are going to burn, but I assume its wood! Most wood stoves work fine with the same size chimney as stovepipe, ours is 6" all the way up, straight. It's like any other piping system, elbows cause a lot of restriction. We even have a double wall pipe from the stove to the chimney, that way we could be closer to the wall, and it gives better draft, hens the stove (Jotul) works better.
