O/T Anyone Loading Remingtom .357 Maximum?
Fergienewbee
Any of you gun guys loading .357 Reminton Max? I'm looking for a good deer load with either 160 or 170 grain bullet. I've seen a couple of loads using H110 or W296 or Bluedot.
Thanks.
Larry in Michigan
Never did .357 Max, but I am not a fan of W296, going to the low end of load can cause big pressure spikes, blowing out primers. There is an IMI powder (Forget the #) that is also prone to this.
its been awhile since i reloaded but i never did reload any 357 max.on some of your powders you got to be carefull.you got to be right in the ball park.because to little you have a two low of preasure and you go very little grains over and the preasures are high.get a good reloading manual and start at the bottom and work your way up and watch for high preasure signs.
I don't do the 357 but I do load 44mag. I use blue dot for my loads and shoot a 245 grain hollow point for my deer load. So far no deer has ever walked away from that combo
I've been loading for years using 2400. If you're going for maximum loads, though, H110/296 is preferred. I'm told that these two powders are actually the same, just different packages. If you go to the Hodgdon site, you'll see that the data for H110 and 296 are identical.
I use Blue Dot for 9mm, where it works well. Supposedly it can give you velocities comparable to H110/296, but it's quite a bit faster than those powders. Since you're going after big game, I think you would be better off using H110/296. Alliant's 158 grain load for Blue Dot shows 1188 fps, while Hodgdon's 158 grain load using H110/296 is a whopping 1591 fps. That's 34 percent more velocity, or 79 percent more muzzle energy.
Agree with Davis SC, don't like W296 much. Had a hangfire with a Ruger 45 Colt while shooting off a bridge once. A hangfire is the primer going off with 1 to 2 second delay in powder ignition. Very dangerous situation. I only load W296 now with a small tuft of fiberfill on top of the powder to keep the powder in contact with the primer.
Joe
It was early in the morning when I first posted, and I mistook "357 Maximum" for "357 Magnum". Still, my recommendation is the same: to get maximum performance out of this cartridge you need a slower powder than Blue Dot. Hodgdon recommends H110 (which is now the same powder as 296) or H4227 (aka IMR-4227).
Hodgdon load data
It's common knowledge that 296 should only be used for full-power loads. Unless you're loading your Ruger to 44 Magnum pressures (which most Rugers can handle), you'd be better off with a slower powder. 45 Colt was originally a black powder cartridge and factory pressure levels are way too low for 296.
