O/T: motorized wire brush
Geo-TH,In
Bigger is not always better. My son got me an 8 inch dewalt grinder for Christmas. I put a wire brush on it and feared for my life and limb. So I put a 6 inch wire brush on a 1/4 hp motor that turns half the speed. It works great! As you can see, I spared no expense in putting it together. The only thing I had to buy was the 2x4 electric box.
you are right, I Remember our high scool shop teacher was using a wire wheel and had safety glasses on , but a piece of wire came out and stuck in his forehead. He walked around to each one of us in the class to show us the danger and how close you could come to losing an eye before he pulled out the piece of wire, than said use a face shield from now on,. He was a very good teacher I remember a lot of things that he taught us.
I do one better. I took an old welding helmet and removed the dark lense. That way I get total face protection. Also wear leather gloves.
George , A angle grinder scares you but that open face brush chopper in your other post dont !?!?
You may find it hard to believe, the way the brush chopper is designed, it only throws the brush to the left, into what you are chopping, or upward. If you look at the mower deck, part of the left side is removed so the blade can get into the brush and do it's work. It is also a good idea not to have anyone standing in front while you are working. I do wear safety glasses. Have been using it for 2 years and feel it it safer to operate than a chain saw or a 3600 RPM 8 in wire wheel. Yet to have anything come after me.
Good idea on the brake drum guard.
I second the full face eye protection. Those particles and broken wires can easily get behind your safety glasses. Our local Rural King sells a flip-up full face shield with a welder style head mount for about $16. It's thin, so it only stops the light stuff - I wear glasses under it. I keep mine hanging on the grinder where it has to be moved before using the grinder.
I've seen a couple of eye injuries and I want no part of that.
Paul
12 or so years ago, I had a wire brush in a side grinder. Brush exploded at full speed. I was wearing safety glasses AND a full faceshield, Thankfully... I pulled dozens of wires out of myself. Thought I had them all, but a year later, I felt a spot on my belly, wound up pulling out a wire that was over an inch long, that was imbedded..
I would add that not all wire wheels are created equally. I've got a cup wheel on my 8" Milwaukee angle grinder and have worn out 2 or 3 before. My neighbor has an off brand grinder and Chinese cup wheel and it vibrates so bad you can't stand to try and hold on to it. If the cup wheel is replaced with mine, the problem goes away. (my $.02).
You've inspired me- I also have a 3500 RPM wire wheel that's scary at full speed. Only saving grace is that it a cheap Chinese model, and about half the starting capacitors are out if it, so takes awhile to get up to speed- so I do my brushing at about half speed.
Have a good motor off a compressor that went south- I think I've got a project.
BTW, the motor is a 1750 rpm. If you do the math, an 8 inch wheel spinning at 3600 rpm is doing close to 86 miles/hr. A 6 in wheel spinnig at 1800 rpm's is only doing 32 mph. It is spinning so slow, you can see the wires flexing as they go past what ever you are cleaning. Bigger is not always better. As for all the parts I used, they were all FREE, with the exception for the electrical box. It cost me $.50. One must have things to accessory their garage. I have a ceiling fan in my pole barn along with a pole barn sized broom.
