O.T - Stihl Weedeater
I was using my Stihl FL-45 Weedeater and the head locked up tighter than a Bull's butt in fly season. I can't even remove the nut that holds the spool on. The Weedeater runs great, just the head is locked up. Any suggestions?
I wish, but I've removed the spool many times. I'm guessing there is a gear down there that has locked up. But still why can't I loosen the retainer bump knob?
I've got one like yours. It's been a good cutter, and I've never had a problem with it, however if you've had the nut off before and can't get it off now, then I think I'd take a vice grip to it and get tough with it. I do believe there is a plug on the lower head that should be removed and greased occasionally..... Lack of lub may be your problem..... Which reminds me I need to grease mine soon. Good luck.
