old
- Location
- Camdenton Missouri
My 8N has a back hoe on it so all it is used for is digging holes. So I have had the clutch pedal blocked down while running or not running. So I took the block off and in neutral the engine stalled. Push the pedal back down and it started up with no problem. I then tried to put it in 1st gear to move it and the engine stalled again like it was in 2 gears. Plus I could not get it back out of first with out firing it up and then had to pull real hard even then. Got it back in neutral and figured I would lift the back wheel off the ground and then slowly let he clutch pedal up. The right side rear tire started to spin since it was the one up the highest off the ground. But it spun up real fast like it was in 4th gear or maybe reverse did not notice which way it was spinning. So has it some how jumped into gear while I was running the backhoe and not it is stuck in a gear with the shiftier in neutral??
I plan to pop the top plate off but that will not be fun since it has the loader and back hoe on it
