Update - Today I replaced the regulator with an Echlin VR950 for later 8Ns with a 2 brush 20 amp generator. The tractor started and ammeter showed 10 amps at fast idle. Moving the throttle up to halfway and the ammeter smoothly went up to 18 or so amps. Took a reading at the battery and it was over 7 volts. Looked at the ammeter again and it was now jumping all over the place fast between 10 to 20 amps. Checked the voltage at the battery again and it showed 7.60 volts. Shut down and restarted the tractor again and once again ammeter smoothly went up to 18 amps then started bouncing again.
Battery is new and shows 6.4 volts after sitting several days. Should it read higher? It this wht the ammeter shows 18 amps trying to charge it?
Is it right or normal for the generator to be putting out 7.6 volts to a 6 volt battery?
Any idea why the ammeter starts bouncing and never settled on a constant reading?
