Odd problem with a B/S engine
old
I was running my big wheel yard man mower the other day when all at once it started to run bad and had black smoke coming out the exhaust. Pulled the plug and yep it was black from gas fouling and running to rich. Pull a spare carb off a junk mower I just got and it works just fine on that engine so I know it has a carb problem. So what would cause it to all at once start to run rich. This is a carb with the tank under the carb and NO adjustments on it just a prime bulb. I even put that carb on another engine for the heck of it and it to runs way to rich with that carb.
So what is wrong??
By the way I have worked on these carbs for years and never seen one do this before.
Hobby farm
What kind of choke does it have?Is it possible that the choke went closed partway?It sounds more like an air restriction to me.
sounds like a sunk float or something in the needle valve/float area stopping it from closing off the fuel.
It's a "pulsa-jet-type" carb, right?
If so, HAVE you check the little pump diaphragm, as I posted about before?
I agree with Bob,replace fuel pump diaphram,may be damaged/bad allowing gas to leak into vacume passage in carb venturi,bypassing hi speed jet causing eng to flood/run rich,also check that check ball behind primer ball not gummed up or dirt in same,not allowing ball to seat & gas leaking by ball.
Haven't opened it up yet but I pretty much figure it is the gasket/pump diaphragm that is between the carb and the tank that is the problem. It is just a junk mower I have so one of these days I'll go spend the $$ on it all of $3 or so
