(quoted from post at 21:28:43 05/11/18)
An offset is not half a tandem
(quoted from post at 04:24:03 05/12/18)(quoted from post at 21:28:43 05/11/18)
Please explain why you think an offset disk isn't similar to 1/2 of a regular tandem disk.
JD built regular tandem disk harrows that they refereed to as double offset because the disk gangs were staggered /overlapped in the center of disk harrow.
(quoted from post at 05:35:27 05/12/18) Mine is fixed mounted. That's good as I figured the designer worked out the best angle for the job and welded it all in place......question is, was that my soil, under my conditions?
I don't understand the compaction thing. This is a cutter not a compressor/cultipactor or however you spell it....I use a roller behind a drill.
