Oil Bath Filter
Niall
Hello, I am trying to clean the oil Bath filter on a super dexta, I removed the bath, opened it and drained the old been there quite a while oil. my problem is the mesh gauze inside the filter, it is really bad and covered in sludge, can I remove this gauze and if so how, I have looked the workshop manual up and down and it does not say how to clean the filter, also I have to fill up the bowl with new oil, does any one know the correct weight for this oil, as I have read before that you cannot use multipurpose oil.
Thanks again for your help,
Niall
I've cleaned a lot of oil bath air cleaners out with laquer thinner. You have to remove the air cleaner and place it in a pan to do it. Pour it in, let it soak, and shake it out. Reuse the thinner in the pan until it gets real dirty and then change it and use some new thinner. Mineral spirits also works, but not as well. Blow it out with with an air compessor after. You will not believe the stuff that comes out. This will allow the tractor to breath much better. Dandy Dave!
I use ATF fluid in my 8N. Depends on your location but where I"m located it gets pretty cold in the winter so the ATF doesn"t get as heavy as say #30 oil. Also I put a little bit of gas line antifreeze in with during the winter months so any water that does accumulate won"t freeze up. This is my own preference, but I don"t have problems with restricted air flow. Also I changed the material in my filter. The first time i washed it out there wasn"t to much left of it.
Good luck.
Brian
Niall
I took mine off and cleaned it . I just used some old fuel we had here that went flat from setting . Soaked it good then took air and blew it out good .
Took quite a time getting her cleaned this way mine was also very dirty . I soaked then put the air to it . Then repeted this about 3 times but finally I could see through the material good .
Good luck .
Lonnie
niall
I remove the complete unit and wash in my parts washer every spring, I blow dry with compressed air and refill with 10W30.
I just clean the cup and refill in the fall.
I do not put that many hours on my tractors in a year, (so far), so this is sufficient.
Brian
