nwb
Good morning, I was cleaning the oil bath air filter on my 1963 Dexta and I was wondering if I do it correctly. I always fill the outside ring to the mark and the inside ring to the holes. Does the inside ring get oil or is it suppose to be dry? My book says to fill to the mark which is only marked on the outside. It says nothing about putting oil in the inside ring. I would appreciated some help.
Hi:
On the MF135 which is very similar to the Dexta, we fill both the inside ring and the outside to the mark and never had any problems.
Also on my FSM we do the same, and it works great.
When you think about it from sloshing around the oil would get into the inside ring so it would seem filling both to the ring would be appropriate. That has always been my logic.
Hope this helps
Kenneth
I was thinking the same thing. It is hard to imagine that I have done it wrong all these years with no ill effects. It is just that the markings on the Dexta cup are confusing. Thanks for the help.
Hello, Can you tell me how you clean the gauze inside the oil bath, can it be removed? and how, my dexta's bath looks like it may have bee on there without cleaning since she was new!!!
Also what oil do you refill the bath with.
I would appreciate any help you can offer me. I canot find anything about clean the filter in my manual?
Thank you for your help,
Niall.
Hello Niall, I posted how to clean the filter in the other thread. The oil should be whatever you run in your engine. Dandy Dave!
