Oil canister tightness question
Tight but not too tight, don't know how else to describe it. Their should be a cooler washer under the bolt head. I recently replaced those washers on mine, I had to buy a pack of 4 from the dealer. About $10 if I remember correctly.
Dave
No washers on the bolt
the CU washer is needed for proper sealing. The base of the housing fits into a groove, in which is a square section Oring. The Oring needs to be replaced almost every time. Usually it appears to be the steel bottom of the groove, and must be picked out with a small flat screwdriver, or other edged tool to get it started out. Tightness is a firm two finger pull on a 8 inch wrench. More is not needed. Do not scratch the groove! Jim
I got it to seal and went out and 1/2 lapped my 2 acre pasture the ground was a bit rough in places. Got it finished, and it was still sealed
