Prawn Farmer
What is the most difficult piece of equipment (tractor, truck or car) that you own with almost no access to the stupid oil filter or drain plug?
(quoted from post at 19:29:06 12/10/14)
The Arctic Cat four stroke turbo snowmobile that I just got considerable diassembly required to get to either.
(quoted from post at 03:06:25 12/11/14) What is the most difficult piece of equipment (tractor, truck or car) that you own with almost no access to the stupid oil filter or drain plug?
(quoted from post at 19:06:25 12/10/14) What is the most difficult piece of equipment (tractor, truck or car) that you own with almost no access to the stupid oil filter or drain plug?
(quoted from post at 19:36:30 12/10/14)(quoted from post at 19:29:06 12/10/14)
T660 or the 1100?
K
(quoted from post at 05:03:16 12/11/14)
It's a 2013 F-1100 turbo Snow Pro, with 1758 miles. I had to get a manual in order to figure out how to take the hood off, LOL. After looking for awhile I finally found the oil filter. I can see it but can't touch it. To drain the oil you have to open two different places. To get at one you have to remove a belly pan that appears to be riveted in. It has lots of electronics which I know will make it very expensive to get repaired when needed. It will probably be my last sled because at nearly 66 years I don't heal like I used to.
