steve terplak
Need some help with a Massey 165. Continental gas with Multi Power.
Was out plowing (backblading) snow and smelled some trans hydraulic fluid. Got off tractor and there appeared to be hydraulic fluid leaking out of the radiator (?!). Turns out it was the oil cooler in front of the radiator. The oil appears to be dripping out of the seal of the filter housing.
The lines all appear dry, the cooler (mini radiator) also appears dry. Seemed to be leaking pretty good out of where the canister screws into the housing.
Could it be as simple as a failed O-ring on the canister? To my knowledge, the filter has never been changed...could that have gotten so plugged and dirty that it created a high pressure situation? I noticed in the parts diagram that there is a spring and a ball...could that have failed? How will this leakage impact tractor performance if i need to use it between now and when i get parts? I don’t know much about this part of the tractor. What will the part availability be?
