oil drain plug washer
TominVA
The only drain plug washer that didn't leak oil from my Perkins engine were those crush washers I used to get from the dealer. The local Massey dealer has been gone for a few years now. Where can I get those crush washers? Local auto parts stores don't appear to have them. What type washer do you use that doesn't drip oil on the shed floor?
Do not know if it would fit, but my toyota sennia van engine uses crushed washers on there drain plugs. Napa did carry them.
There are two things that you can try to seal your sump plug,
Fit a bonded hydraulic sealing washer (not sure what you call them in the US but they used to be known as Dowty washers many years ago here in the UK)
Alternatively clean the thread of the plug and apply some hydraulic sealant (Loctite 542 or similar) before refitting.
