oil filter 53-59
raphael
53-- 59 ford tractor oil filter will a ph8a work & how much oil will be needed. i am still not sure which engine i have.
thanks
raphael
Yes! a PH8A will fit, however I don't recommend Fram filters. Motorcraft FL-1A woud be best. You need 5 quarts . . . and an operator's manual.
Likely 53-63 they will fit. so will a napa 1515 and a whole slew of others.
what tractor ya got?
look ont he trans bellhousing for lightly stamped numbers.. just aft of the starter.
soundguy
i have i think a jubliee with a block in it 310609 if read right make it a 58-59 with no ser #. i also have a leak in the rear end so i drained some off. i still have oil on floor so maybe i should drain moreoff ? my draw bar seem to me to be more jerky wheather on the brush hog or just sitting idel.also it seem tome that when i go to shift gears it grinds maybe i should idel it down before shifting. i am enjoying my first tractor & do not use it hard.it has a sherman tran. in too. also i put on tires from a front wheel asst. tractor not a good ride going slow but great goning down blacktop wide open.i guy told me to grind off the high spot and the shimmy would go away? with that said i will change the oil this week when @ the farm.
enjoy
regards
sound slike you might have a leaky trans seal oiling the clutch causing it to stick.. rear leak hard to say.. where are you loosing the oil.. from the rear end?
soundguy
