oil filter inlet line
Greetings list: I have a 51 8N. I don't seem to be getting oil flow through the 1/4 inch or so line that goes from the block to the top of the oil filter canister. I know that because I have a piece of clear plastic tubing temporarily installed. Any thoughts? Thanks in advance.
(quoted from post at 17:08:11 10/10/16) Greetings list: I have a 51 8N. I don't seem to be getting oil flow through the 1/4 inch or so line that goes from the block to the top of the oil filter canister. I know that because I have a piece of clear plastic tubing temporarily installed. Any thoughts? Thanks in advance.
howing any oil pressure?
pull the hose off while running, prpare to get sprayed in oil. With that pressure, there should be oil going to filter. if not check the tee fitting for blockage.
