oil for dist.
gutterman
how often should i put oil in the distributor, and how much..i am asking about the small part with the spring loaded lid on a side mount 8n..... I'm sure this could have been worded different, but didn't know if y'all would know what i meant by saying, the snooder sticking out the dist what has a flapper on hit. is it for oil? thanks
(quoted from post at 23:28:56 01/26/11) how often should i put oil in the distributor, and how much..i am asking about the small part with the spring loaded lid on a side mount 8n..... I'm sure this could have been worded different, but didn't know if y'all would know what i meant by saying, the snooder sticking out the dist what has a flapper on hit. is it for oil? thanks
perator's Manual gives all lubrication information.
every 10 hours, 20 or 30 wt motor oil.
And where can I get a replacement oiler for my side distributor?
My lid is no longer spring loaded and stays up inviting dirt.
Clem
if it has not been oiled in a while, load it up with some wd40 or pb blaster to get the wick 'flowing' then use whatever oil is handy. i've found the nozzle of a 3-in-1 oiler bottle works fine to add a drop or two now and then.
same with the oiler on a genny.
soundguy
I over oiled my generator and got oil on comutater and generator quit working, Had to disassemble and clean it out/
