(quoted from post at 06:35:49 06/08/11) Joe, the cheapest way to check out your problem is likely 1- check it again with another gauge 2- Take Dells advice and use a single-weight, heavier oil like SAE 40 or SAE 50 even.
Hell..it's SUMMER and you don't need a multiwt oil in a Ford tractor any time of year at all, anyway.
The Old Hokie means well. But he's wrong to jump on Dell so personally and so critically. Dell is correct. The Old Hokie wants to confuse everyone with his superior techie-talk about oil which does NOT APPLY to this matter. He wants Dell, me, and you to admire his tidbit of speshul knowlege about multi-weight oil...but overlook his stoopid use of the word "motor" when he means ENGINE. If he want's everyone to be so perfect about oil he should at least be consistent about being picky on himself too.
NO PERSONAL ATTACKS ARE MERITED HERE, in my opinion.
JOe..there's one more possibility that may be overlooked. YOur oil pump pickup may be defective. If your pump produces oil pressure when the oil is cold, but not when it's hot... it may be due to worn engine parts and may be helped (and the repairs deferred) by using a heavy weight single grade oil. I do that myself on my tractor, and it starts out at 35 psi cold and when hot has dropped to 20 psi at higher rpms while working and 5 psi at idle. Been that way for years and years with no harm and no big money out of my pocket rebuilding the engine, which continues to do good, hard work regularly. Cheap fix. SAE 50 aircraft engine oil, year roujnd, hot Texas summers and cold seventeen-degree TX winters. Multiweight sucked and failed to hold pressure and lubricate. Dell's simple answer works (regardless of what "scientists" say.)
That other possibility might be related to your oil pump pickup tube. If it's loose, as the oil warms it may allow more air to enter the pump until it cavitates. The fix will be to remove your sump drain, and see if you can "wiggle" your oil pump pickup tube. It's up above the big drain plug/screen, and leads to the pump body. (Get yourself an IT FO-4 manual from Tractor Supply or this website if you don't have one. It's your very best tool, ever.) If the pickup tube is loose.. then you'll have to remove the sump and braze/solder the tube to the pump. It's a bit more trouble but not expensive.
