NoMoreCash
I have scoured the old posts on the oil pump gears and backlash. The last one I read said that backlash didn't matter as the gears seal when they are driven. I understand this and think that the oil pressure is not greatly affected by the back lash because of this. But I am concerned with the back lash when it is larger than what is recommended, specifically for maintaining the prime of the pump. Wouldn't a larger gap be prone to losing the prime when the engine sits?
I have just redone my 9N engine and put it all together, started it up (sounded good) and had initial pressure of 30 pounds on a new gauge. When I turned it off, 30 min later it had no pressure when I tried to restart it. I had to prime the oil pump to get it to get pressure. Upon inspection of the oil pick up tube showed some movement, so I took off the nicely matched oil pan to inspect closer. I discover that the solder joint on the pick up tube had cracked, so that could be the main reason for the loss of prime, but upon closer inspection of the gears they have .024 inches of clearance for the backlash. So before I put it back together I am hoping that I can get some comfort in knowing that this much backlash is going to be okay and I won't have to have the oil pump pulled a second time to correct this. I did take the pickup tube and brazed the joint, it seems much more solid than before. Anything else I should consider, or do I just put it back together?
Thanks for your thoughts on this ahead of time.
