(quoted from post at 16:03:12 01/29/15) Check out tip # 51
75 Tips
(quoted from post at 08:21:20 01/30/15) Serge.......yep, the ol' jingle-jangle cotter keys designed to keep dirt from pluggin' the drain hole. In the old days of before sprays, weed control was a dusty dirty chore of draggin' V-shaped sweeps just under the DRY soil. The jingle-jangle cotter keys kept the 2-holes free to drip oil. Most oil drip is NOT engine oil but tranny oil drip. While the 1939 design spec'd 5-gals of 90wt gear oil; Ford now recommends spec: M2C-134D. (about 60wt) Most front tranny seal oil leak is caused by OVERFILLING. N's run just fine on 4-1/2 to 4-3/4 gals of M2C-134D. Not only that, but you won't be splashing oil out yer axle seals and greasin' yer brakes. ......oily Dell
(quoted from post at 16:33:05 01/30/15)(quoted from post at 08:21:20 01/30/15) Serge.......yep, the ol' jingle-jangle cotter keys designed to keep dirt from pluggin' the drain hole. In the old days of before sprays, weed control was a dusty dirty chore of draggin' V-shaped sweeps just under the DRY soil. The jingle-jangle cotter keys kept the 2-holes free to drip oil. Most oil drip is NOT engine oil but tranny oil drip. While the 1939 design spec'd 5-gals of 90wt gear oil; Ford now recommends spec: M2C-134D. (about 60wt) Most front tranny seal oil leak is caused by OVERFILLING. N's run just fine on 4-1/2 to 4-3/4 gals of M2C-134D. Not only that, but you won't be splashing oil out yer axle seals and greasin' yer brakes. ......oily Dell
Why keep dispensing that same flawed theory? Overfilling does NOT cause seals to leak, BAD seals leak. Good seals do not leak. The front transmission seal as well as the axle seals are neoprene lip seals. They are designed to keep oil in even when completely submerged below gallons of oil and they do it well every day in numerous applications. The oil level in the N transmission and rear end even when full is WAY below the input shaft and axle shaft level. Lubrication is provided by splashing. When the gears spin in the transmission it looks like an automatic car wash spraying oil around in there. The gears, being in the lower part of the transmission, will fling oil all over whether there is one gallon or 5 gallons in there. Running it a quart or 2 low will have NO effect on the seal leaking if the seal is bad. And only bad seals leak.
