Oil Lub.Compressor
Larry D.
Anyone Here Have the HUSKY(Campbell/Hausfeld with 2HP Mtr and 30Gal.Tank.Oil Lube Single stage Comp. and how do You like it, Thinking it's what I need for the Shop,for Ocassional Use, don't like the Oilless Type.. Thanks Larry KF4LKU
I'm upgrading my shop air. Have a nice 5hp, 30 gallon Coleman to get rid of. It's just four years old and looks like new.
Gordo
I bought this compressor a couple years ago for around $400 and have been quite pleased with it.
30 gallon tank, two cylinder cast iron oil lubed pump, 110v. It's nice to be able to wheel it over to the neighbor's (or anywhere) and just plug it in. Keeps up with the impact wrench just fine, used it on a small cabinet bead blaster for a couple of days and it worked fine for that, too. I wouldn't recommend it for long-term sand blasting, but for everything else it works just fine.
Being belt driven, the pump actually runs at a reasonable speed and should last quite a while, too. I have a Coleman PowerMate at the farm that is similar, except the pump is aluminum with cast iron liners.
