grandpalonghair-HT
Yanmar 1500D w/ FEL
Any ideas why oil is pukeing out from the front crank seal all of a sudden??????????
/e></QUOTE></s>pully not loose.
will pull front cover to replace seal.
what size is the crank shaft nut??<e>
/e></QUOTE></s>Tried Norm's suggestion and no go, anymore ideas?<e>
</s><QUOTE author="grandpalonghair"><s>/e></QUOTE></s>Tried Norm's suggestion and no go, anymore ideas?<e>
Don't know why. Battery and starter are in the same shape as when I shut down for the leak, never had a problem starting this tractor. Probably will borrow an impact wrench.
</s><QUOTE author="Norm"><s>/e></QUOTE></s><QUOTE author="grandpalonghair"><s>/e></QUOTE></s>Tried Norm's suggestion and no go, anymore ideas?<e>
Don't know why. Battery and starter are in the same shape as when I shut down for the leak, never had a problem starting this tractor. Probably will borrow an impact wrench.<e>
You are probably going to need 500-1,000 ft. lbs. of torque. I'm assuming you are saying the battery and starter were not strong enough.
/e></QUOTE></s>If you can borrow a 1/2" impact wrench and compressor or use an electric one it will come right off. That is how I got mine off.<e>
